G
Guest
Guest
Archived from groups: microsoft.public.windowsxp.messenger (More info?)
My nephew and I are both running MSN Messenger v 6.2
(6.2.0137)
However, he has the ability to add what I would call
an "audio emoticon" (best way I can describe it) to his
instant mesages. Examples are a Vincent Price type horror
laugh etc which is played over the recipients loudspeakers
when the message it sent. There are a whole load of other
audio add on's.
He adds them from a drop down menu accessed from an incon
over the "Send" button in the composition pane. This icon
is additional to the Font, Emoticon and Background
options which also appear.
This option does not appear on my version of MSN Messenger
and I wonder where it can be obtained. I thought perhaps
that MS had released a new version of MSN Messenger but
I've not been able to locate it.
Has any other user of MSN Messenger got this option and
can you tell me how you obtained it? My nephew can't
recall; he thought it was included in the application when
he downloaded it but if this was the case why is it not on
my identical version?
Thanks for any help anybody can give
Peter Kemp
Chelmsford
UK
(6.2.0137)
audio add on's.
Peter Kemp
Chelmsford
UK
