Hello,
So for a few weeks I have been experiencing an issue where audio coming from my computer is severely distorted. The only way I can describe it is as if someone was playing the sound underwater. I have tried many 'fixes' found on the internet including:
One thing in particular I have noticed in regards to this situation, is that at random intervals, the sound will be 'normal' for a few minutes, and then return to the garbled state it is usually in for anywhere from half an hour to one hour.
If anyone can identify the problem and/or offer potential fixes, it would be gladly appreciated. Thanks in advance.
System Specs:
Motherboard: ASRock H97M Pro4
CPU: Intel i7 4690K LGA1150 Quad-core
Memory: Kingston Fury Blue 2x4GB DDR3
GPU: MSI GeForce GTX 970
PSU: EVGA SuperNova 650W
Cooling: Coolermaster Hyper 212 EVO
Case: Coolermaster Storm Enforcer
OS: Windows 8.1
■ Uninstalling and reinstalling audio drivers
■ Changing headphones
■ Removing programs of potential audio interference
■ Making sure everything inside the computer is seated properly
■ Using Realtek HD audio manager
■ Using Windows troubleshoot tool
■ Contacting Windows support
■ Making sure I have the right codecs
■ Running several virus scans
■ Changing settings in playback options
■ Disabling CPU Throttling
■ Changing power plans to full performance
System Specs:
OS: Windows 8.1
