Audio front panel?
G
Guest
Guest
Archived from groups: alt.comp.periphs.mainboard.asus (More info?)
I wan't to use the feature on my P4P800 Deluxe to connect audio
inputs/outputs from the mobo to a front panel. However I can only find
front panels with regular jack-connectors which destroys the fun of
having the front panel IMO, because I have to steal the back panel
plugs. And since my awesome motherboard has this feature, why not use it?
Does anyone know of a front panel audio breakout with connectors that
suits my mobo??
/Mikkel
In article <cno6sd$1g4d$1@news.cybercity.dk>, Mikl
> suits my mobo??
> /Mikkel
The Asus J-Panel is a solution. This product sits in a drive bay,
and has a USB 2x5 connector and a FPAUDIO 2x5 connector. The product
may be hard to find, but I still see it listed with a few companies.
http://www.de.tomshardware.com/motherboard/20030328/images/asus-jpanel.jpg
For an even more DIY approach, try FrontX:
http://frontx.com/cpx110.html
The CPX110 gives you a microphone and headphone jack, and you can
buy other internal style cable assemblies, like some USB2 ports,
then get the casing, which holds the items in place, in a drive
bay:
http://frontx.com/cpx088.html (casing to hold multiple jacks)
HTH,
Paul
