AUDIO ISSUES WINFAST 760GXK8MC
cesar8422
Hello,
Hi
i want to ask somethin about the motherbaord winfast 760gxK8MC ?
the computer got an issue with the integrated audio port. the sounds are distorted I already update the audio driver but the issue persist. and also i change the memory ram into the other slot and its working a little bit better do you have any answer on this please. thanks a lot
Did you find the correct drivers for windows xp ?
I needs the audio driver can you help me please??
Thanks a lot
First download AUD_ALLOS_5.10.00.6040_PV_REALTEK Driver and install.Then download audio driver 5410 from Foxconn download centre.It works and it took me ages to find the answer to this common problem.
