maybe you have to choose the right audio output channel in your audio settings
There’s something wrong with the jack itself or the connections to the mobo. If your plug goes in and out very easily, the clamp is probably loose. If this not the case, get the solderings checked.
Use USB speakers, headsets or just a USB to 3.5mm audio jack converter.
