Audio Jacks are Messed Up on my motherboard
Josh_2001
Commendable
Apr 6, 2016
4
I have a Gigabyte GA970A-UD3P which uses the Realtek HD Audio Driver, and I have a problem with it. Whenever I plug my Headset into my motherboard (headphone and microphone jacks), the driver registers them as different color ports (eg. Green Jack is registered as the Black Jack)
My front ports also fail to register successfully.
If anyone has had this problem or has a solution to this problem, please let me know in the comments, thanks.
Well I'd have to say your problem sounds like a factory fault. Can you trial and error until you have the jacks matching up with the correct colours? Front ports would be far more likely to be a faulty connection or a mispluged cable, or something of the like, check the connections and make sure they are all correctly plugged in, then check the cabling.
If I'm off track here please explain in a little more detail. Thanks!
