audio not working on nvidia motherboard
Jun 7, 2018
motherboard audio on the nforce 680i sli not working with 3.5 mm jack but when i use any headset with USB it works fine i am running windows ten and have tried drivers resetting my PC and changing cases this audio problem is driving me mad any help would be appreciated
If you've installed a graphics card which has integrated audio chip (most do nowadays), and you've installed audio drivers along with GPU drivers from the Geforce or AMD driver package, that's what's causing the problem as it is now the default audio device instead of the device which outputs through the 3.5mm audio jack. USB headphones still work because they incorporate their own sound-chip in the headphone housing.
What I did was uninstall the graphics driver package completely, then re-installed using the custom-install option, making sure to deselect the audio drivers. This restored the motherboard's integrated audio as the default.
Oh my god thank you so much i will go ahead and try this now
i went ahead and uninstalled all of the drivers using ddu but i haven't been able to fix the problem for for some reason the headset is still not showing up and my PC says that the 3.5 mm jacks are empty
