Audio through HDMI Troubles.
Mythstatic
21
Hey guys, so here is my situation. There is a computer hooked up to a small monitor via VGA. Then there are two display ports coming out of the back of the computer that adapt to HDMI connecting to two different large 4k vizio TV's. When I have just one of those TV's connected, I can send audio to it, (the device in sound manager shows as plugged in and working). However when I plug the second TV in, the device in sound manager shows as "unplugged" and I cannot send audio to either TV. Any thoughts?
Without knowing the exact equipment (computer wise) what I can tell you is HDMI connections have these kinds of quirks. It is likely a built in limitation that won't allow it to transmit to both, as for the reason maybe they would expect you to be using a separate external sound system off the built in sound card on the pc.
