[citation][nom]patrick47018[/nom]While this is true, MicroCenter has a great return policy, I'm not sure about Overlord, but I do know the one that is under 400, its 384, only has DVI, while this has HDMI, DisplayPort, DVI, headphon jack, and VGA. So if you just want DVI, getting an Achieva Shimian is cheaper off of ebay, but then also you have to deal with possible shoddy return system. Good luck to all and I will comment once I have my Auria, I'm going from my 40" Auria 1080P HDTV to a Auria 27" 1440P IPS monitor, good trade I think.[/citation]
Most video cards have Dual link DVI so this isn't really an issue unless yours does not. I use a Catleap Q270 monitor right now (let me tell you, there is NO going back for me after getting one of these, 1080p monitors are as good as yesterday's trash to me). This was a B grade panel and it ended up having no visable defects or bad pixels (I only paid $245 for it off of ebay new from Korea, they've gone up $100 since). The reason I ended up going with the panel I did was from a quite extensive post on hardforum detailing how the DVI-only monitors were having incredibly low input lag compared to any of the other 1440p IPS panels available. I'm getting incredible framerates with my 670 and my games are streak/ghost/stutter/tearing free.
Maybe this Auria monitor just can't hack it vs. its' Korean counterparts.
Also it's good to know you can always take apart these monitors and replace the PCB so that you can overclock them to 120Hz, but Overlord is the only place selling the part and it's $200 🙁
