So I have a very irrating problem with a build that I am currently working on.
When everything's assembled and connected in the case I cannot get system to post due to B2 Load VGA BIOS error.
When I take it out of the case and bench test the system it posts and boots perfectly with no errors.
I have done this 3 times now but the problem still persists.
Equipment list as follows:
Asus ROG Rampage VI Extreme MB
Asus ROG Radeon RX850 OC GPU
Intel i7 7800X CPU
Intel 660P M.2 SSD
G.Skill Trident Z RGB 32gb RAM
Thermaltake IRGB 1250W PSU
Thermaltake Riing Plus fans x 4
Thermaltake Floe Riing 360 CPU cooler
Thermaltake TT Premium 300mm GPU riser cable
Thermaltake View 37 case
I have tested the GPU and the PSU independently and both work perfectly.
All cables are connected correctly and the riser cable has also been confirmed to be working perfectly.
CPU is also perfect and socket has no bent pins.
As the system works without issue outside the case I know it is not a hardware issue.
All drivers are up to date and the bios for the GPU has been reflashed and operates perfectly outside the case.
The only items I have not connected outside the case are the fans and the AIO cpu cooler as these should have no bearing on the B2 Load VGA BIOS error.
I am an experienced builder and have not encountered the issue before on other X299 builds but it is becoming tiresome having to remove the MB/GPU/RAM/CPU and PSU plus cables every time only for th issue to remain.
If anyone can assist me with a resolution it would be very much appreciated.
Intel i7 7800X CPU
Intel 660P M.2 SSD
