Question b450 aorus pro gaming motherboard rgb fusion v2.0 not working.
Oct 28, 2019
11
i updated the software into RGB fusion v2.0 , now all my rgb is not working. and i cant run the rgb fusion anymore it keep on crashing
RGB app's are known to be buggy and at best work when you least expect them to. Maybe see if you can revert to an older version of the app. Also, see if updating your motherboard BIOS helps with the issue.
You forgot to mention the rest of your RGB parts in your ecosystem.
The motherboard rgb can't sync and
The darkflash fans can't sync
Same with Asus ROG Z390 Gaming mainboards, one day works, other day does not work, when started the day after it again starts to work. I don't like these lights, but when I want to buy a good mainboard, they are with the package, and when I have them I need to set them. 🙁
