[SOLVED] B450 Tomahawk MAX for Ryzen 5600X or 3600X?
DragFire
5
Hi guys,
My old motherboard/cpu/ram died and I cant find what exactly or how to solve it. I have RAM and CPU red leds and I think it's a good time to upgrade.
I will keep the box, SSD, bronze 620W psu and nvidia GTX 1070.
I grabed a dirty cheap B450 Tomahawk MAX II (60€) and Team Group RAM 2x16GB 3200mhz CL16.
I only need a CPU. The Ryzen 5600X (285€) seems good quality/price because its not much more than a 3600X (240€).
I will use it mainly for flight sims with a high need of single core speed and I dont want to deal with OC, perhaps the automatic Boost but I don't want to touch voltages and deal with instability.
Questions:
  1. Is it meaningless to aim for Ryzen 5 5600X with a GTX 1070 because the videocard may be the bottleneck for FPS?
  2. Will I have worse performance with the B450 than a B550? For example the Asus TUF Gaming B550 Plus (130€), something low entry. I still can return the B450.
I researched all I can and I still have this doubts :S. Thanks for the help!
There should be no performance difference between the B450 and the B550 Boards, differences don't show up when using a 6 core CPU anyway, the only time you NEED to be worried about the quality of the motherboard is if you're going for a higher end part like a Ryzen 9. You will however have to update the BIOS on any B450 board to support a Ryzen 5000 CPU. B550 boards will have that from the start.
Unless you're going for 1080p super-high refresh rate gaming(240Hz+), there wont be any advantage to go for the 5600X especially if you're only pairing it with a 1070.
Reactions: DragFire
