BAK N18650CP 3350mAh -6.5A or LG INR18650-M36 3450mAh - 5A
pasta330
Commendable
Aug 2, 2020
5
Hello.I want to replace my 6 laptop cells which are Sanyo NCR18650BF 3350mAh - 4.9A and i am thinking either
BAK N18650CP 3350mAh - 6.5A or
LG INR18650-M36 3450mAh - 5A.
What do you suggest?
A little bit more of a battery, "slightly" but a little more. And the factor that it's at 5amp Instead of 6.5 should technically last a little longer not putting out as much power. That and it's less likely to accidently over volt a component due to have similar power ratings as the current battery. Jumping in amp output means that if there's a fault in power management you may accidently fry a component
