I want to build an incredibly basic PC that will play some very old games. I don't need much power but I just have a couple of questions. I have a lot of old parts lying around that I want to use. PC PartPicker does not really report information on this "old" hardware as far as compatibility.
Question 1: Can I use an old HD 7770 paired with an A-series APU? I don't need much power and I am looking at an A6-7400K dual-core APU. I don't want to run into issues with an APU + dedicated GPU. The Motherboard I will be using is the Gigabyte GA-F2A68HM-H.
Question 2: This system will not use close to the 500-watt PSU, but this build is all about not purchasing what I already have. Is it going to be okay to use a higher watt PSU on a system that does not really need it?
Case: Thermaltake VERSA H15
Motherboard: Gigabyte GA-F2A68HM-H (Socket FM2+)
CPU: AMD A6-7400K 3.5 GHz Dual-Core APU (Radeon R5 Series Graphics)
RAM: Corsair Vengeance LP 8GB 1600MHz DDR3
GPU: AMD Radeon HD 7770 1GB GDDR5
Storage: ADATA SU800 128GB
PSU: Corsair CX500 80+ Bronze (Non-Modular)
