Question Batteries question for a particular power supply
Ragahv
189
Input: 100-240V 3.2A 50-60Hz
Output: 19.5V 11.8A 230W
My computer is the : Zotac QK7P5000 PLUS Mini PC. You can google this mini pc.
I just want to ask what type and what rechargeable batteries I can use inside the pc case, to make it last for 5-6 hours on high performance and while gaming on ultra settings?
I don't care about the charging time. Just tell me of any light weight battery that I can use in the mini pc depending on the input and output power rating specified above
Case is to small for a battery that could run it for any appreciable amount of time. Even if find a 19.5v one it would be a size of motorcycle battery to run it half an hour or less.
Your best bet is an UPS. You would also need a power source for monitor, what about that ?
Ragahv
189
If the price of the battery will be more just let me know which one it is anyway. My budget is around 4K anyway. My motherboard is chosen - Mini ITX form factor and 16GB DDR4 RAM 2400MHz, 1TB SSD M.2 and Mobile GTX 980 GPU
So what battery to use to make it last for 5-6 hourts on high performance?
There is no battery of that capacity that can fit inside the case, period,
Ragahv
189
15,000 mAh battery 57Wh - what about this one? The GPD WIN MAX has a battery with the specs: 15,000 mAh battery 57Wh. Some mini ultra books have it. So it's 3 times 5,000 mAh with 14.5Volts
