I wrote Gigabyte (got a support ticket) but so far have heard nothing at all about my question, so I thought I would put it out here.
(and I also searched the net, but didn't find any helpful information on this)
On the Gigabyte Aorus B450 I Pro Wifi Mini-ITX motherboard, the battery is sort of on its spine (rather than flat), tucked
next to one of the I/O components and under a metal thermal heat shield/heatsink. How does one get to it? Does this
metal thermal shield come out or slide or what? I don't want to damage anything, but need to access the battery so I can
unplug it (it apparently has a plug into the motherboard, and the plug is also underneath the shield.
Here is a photo of my mini-itx motherboard, with text I added to label where things are:
View: https://imgur.com/Y3mmlWP
It's a new build, so I had some problems with the CPU pins getting bent, but fixed the pins, yet not before
probably corrupting the BIOS, so I have to do more than just the screwdriver to the CMOS here, and that
requires removing the battery for awhile. But that metal is in my way--what were the thinking?
Anyone have any ideas, or anyone run into a similar problem?
