I am having battery/power problems with my Acer Aspire E14, E5-471.
I was having power problem, laptop was disconnecting from AC power. Problem would be solved if i just pressed/rotated the power pin near the charging port. I thought it was power adapter problem, so I purchased one. But the problem got worse. Battery wouldn't hold charge. Then Laptop kept shutting down suddenly and very rapidly. Very very rarely (1 or 2% of the time, IDK) it can be used (stays open) for several hours, until it shuts down evantually. This problem happened/developed over a timespan of 3 or 4 months, i’d say.
I knew that Laptops can be used with direct ac power without the battery. Just noticed that my laptop doesn’t get power while the battery is out.
I have a desktop, so I don’t rely on the laptop that much. But I’d like to have it back for emergency/ vacations. I am not exactly hoping for a solution online, it would be awosome though. Just seeking your insight on the problem.
Laptop keypad had problems. Which was replaced from service center. And I told them about the problem at that time. They didn’t care much & didn't look for the problem, or didn't found it, I suppose. They just said they didn’t have replacement battery. Laptop speaker stopped working after replacing the battery. I didn’t notice that at that moment because I didn’t play anything to check the sound. Anyway, that’s not the problem here, just saying in details if it helps. Windows 10 OS, Intel core i5, 4 GB RAM. Please let me know if you need to know anything else to better understand the problem.
Thanks in advance.
Thanks in advance.
