Question Battery wear level is at 90% but it does not hold any charge ?
Dasa
101
Hi,
I got the idea the battery wear level of 90% is good but charge level is 0% and it doesn't not hold any charge, I remember laptop used to stay on for 5sec before turning off when unplugged.
additional info from cpuid harware:
Designed capacity 47520 mWh
Full chrage 5141mWh
battery indicator is orange on laptop body
What's the deal here?
Edit:
Voltage 4.23
Windows says "plugged in but not charging"
so the laptop is not charing the battery?
Correct
"Windows says "plugged in but not charging"
Check the power cable for any damage. You may want to get a new one and see if that helps.
So a damaged cable could run the laptop but not charge even when laptop is turned off? because it never gets a charge
There is one thing I didn't mention because I am not sure about it, I'm not sure it the original adapter but I did search by model number and it is an original adapter made for Acer (made by Lite-on) according to several sites
