First of all, I know this is a wide known problem, but I just don't know what else to do but to ask here.
So, BF1 is running horribly on my PC, it stays at a constant 40-50 fps (it is at 120+ on menus, but drops to -50 as soon as I join a match), occasionally dropping to the 20s, it stutters like crazy and it is almost unplayable, whether I set it to low or ultra it behaves almost the same (there is some performance improvement form high to low, but very little, even at lowest settings the framerate is still very low). But as far as I can tell my computer should be able to run it decently, maybe not on ultra with all the fancy stuff on and at 120+fps, but at least at medium with decent frame-rate, also, this is exclusive to BF1, all my other games work just fine at max (or almost) settings, anyway, here is my rig:
Processor: Intel core i7-5820k
Graphics card: GTX980
Ram: 16 on four 4gig sticks
Mother board: Asus Rampage Extreme V
OS: Windows 10
Cooling system: Corsair Hydro Series H105
Power supply: Corsair rm 1000
I've tried basically everything there is online, messing with Nvidia control panel ("pre-render frames" and what not), the user.cfg file on the BF1 folder, I tried unparking my cores, I tried overclocking both my CPU and GPU, messing with the BF1 video settings (obviously), I have all my graphic drivers up to date (I tried rolling back to the previous driver since some people reported having their BF1 screwed up after the latest driver, didn't help either), setting BF1 to high priority on the task manager, I tried disabling Speedstep on BIOS, I have cheked for GPU and CPU usage, both stay at around 60% (no idea why my gpu is not going higher, I suspect this is part of the problem but can't find a way around it...), anyway, I've tried everything I could find and nothing has worked, I'm getting desperate here, any help would be greatly appreciated, thanks and sorry for the long post.
OS: Windows 10
