K KenzieHD Reputable Dec 23, 2014 23 0 4,510 Mar 5, 2015 #1 Hi, I have random FPS problems when playing battlefield 4 after the new patch that came out the other day. My pc specs are. CPU - i5 4440 RAM - 16gb GPU - r9 270x
Dylzan Honorable Aug 2, 2013 1,238 0 11,660 Mar 5, 2015 Solution #2 Check your temps, reinstall the drivers, report back. Upvote 0 Downvote Solution
J junkeymonkey Polypheme BANNED Nov 11, 2013 17,389 5 66,960 Mar 5, 2015 #3 if the patch is a issue then just don't install it ? its that simple , right ? if thing were fine before the patch that keep playing it that way Upvote 0 Downvote
