Battlefield 4 low fps out of nowhere.
herrmant
124
I use to run BF4 at 45-55 fps... All of a sudden I am getting 20-15, or even 3 at times... GPU usage is at 98-97% and cpu is at 76-80%.... Low settings are the same result... Quality changes but FPS does not...
here is my specs...
AMD Athlon 860k OC'ed to 4.2
R7-250X
Msi a78m e35
8gb ddr3 1600...
Temps aren't the issue as gpu is 55*C and cpu is 40*c under load. AMD OD thermal margin is 46 underload. Thanks in advance.
is it stuttering? or is it stuck at 15-20 FPS? i know i get massive frame drops when post-processing is set to anything higher than low, on my 7870 (R9 270X). other than that i get ~80FPS on 32p OP Locker, with mostly high settings at 1920x1200.
