[SOLVED] Battleifeld v not using 100% of the cpu and gpu
Jan 14, 2019
6
Hello so i have a battlefield 5 and i am playing with a 144 hz dispaly and i am just geting 70-80 fps and my cpu and gpu usage is at 50-70%
my specs
Custom loop med følgende komponenter:
EK-CoolStream XE 240 (radiator)
EK-Vardar (Vifter)
EK-RES X3 (reservoar)
EK-Supremacy EVO - Gold (cpu block)
EK-XTOP DDC 3.2 PWM Elite - Plexi (pumpe)
TUBE PrimoChill PrimoFlex™ (tubing)
EK-CryoFuel Blood Red (kjølevæske)
Øvrige komponenter:
Intel Core i7 6700k
Asus Rog Strix 1080
asus maximus viii hero
16gb Corsair Vengance 3000MHz
Corsair RM1000i
Samsung 840 series 500gb ssd
seagate 2TB sshd
Svive Luna s700
Check to make sure your GPU is working correctly. Run a GPU stress test like Unique Heaven and make sure your GPU is hitting the correct speeds. Is the GPU overclocked?
Your...
Based on your specs, you should get great fps. And you have a higher end GPU than I yet I seem to get better fps, and I play at 1440p.
Are you playing on 1080p? 1440p? or 4k? If at 4k then those fps I wouldn't be surprised but I am shocked about the low utilization of CPU n GPU. My 7700k is at around 90% and GPU 100%.
Also, you gotta tweak some in game settings to help improve the fps. Look into that for fps help.
But the fact that your GPU isn't at 100% is weird.
I have a 1440p display.
My temps on cpu is 40c and gpu 70c
i have overclocked the cpu to 4,7 but the gpu and cpu is at 100% on other games
i am playing on a 1440p and i have turned down ingame settings but still the same thing
hi i am plying with 1440 p monitor and i have turned down many settings on bf 5
Your 6700k @ 4.7GHz is essentially the same as mine. But my gpu is equivalent a gtx 1070. So, you should have lots more FPS than I. But only 50-70% gpu usage is weird. Try using MSI Afterburner, it is GPU software that can be used with any brand of GPU. In there, under Settings > Monitoring you'll find things you can put on a Graph. I use this to watch my GPU temps, GPU usage, and so forth.
Give those two softwares a try.
Things have changed. Running Dx12 with a Nvidia GPU is now doable. And even in BF V. But when I say its doable, I mean as of Dec 2018. Back in Oct 2018, No.
What I would suggest is playing BF V with DX12 and see what kind of FPS you get. Then do same with DX11. Use whichever is better then.
