BCLK and disabling cores questions
Hi, I have my Core i5 2500k stable at 4.5Ghz, which is good enough for me considering I only have a single GPU, but I just want to see how far I can push it. I am running a Corsair H60 cooerl and an ASROCK Extreme3 Gen3 motherboard.
I have heard that tuning the BCLK on SB chips can hurt the CPU and board, but I know some people have done it with success and have not had issues. Would something like a 3-5mhz tuning of the BCLK hurt the chip?
Second question about disabling cores. I wanted to see how far I could push the overclock with just 1-2 cores running and set my machine to 4.8Ghz and went to boot but it would not even post and I had to clear the CMOS. How can I disable cores and still boot? Am I missing something? It seemed pretty straight forward, but obviously it isn't working.
pcie frequency is the pcie bus speed; its how pcie device communicate with the cpu & ram. Stock is 100Mhz. How far you can 'tune' it often depends on what devices are on the bus.
Bclk is the internal Intel Base Clock and potentially effects everything. If you change it 10% you might change all the other clocks too like cpu speed (bclk*multiplier), quickpath (QPI), memory, and PCIe though most motherboards now include bios settings to individually control those speeds.
As for overclocking the bclk, exept for the k series chips, the bclk is all many people get to adjust. Overclocking in itself can cause damage. I dont think overclocking the bclk would hurt and worse. I've seen a few system hit 220mhz bclk but most stop around 200.
edit...
For the base clock, that's tied into a lot of sub systems. I don't know exactly what the effect would be, but generally people are worried about how it affects the PCIe frequency. Well, on my PC I've had my PCIe up from 100 to 130. I run mine daily at 110. There were some issues with it up at 120-130 but nothing that isn't fixed by reducing it. I'd say you could probably get 5-10mhz out of the base clock, if the PCIe is the limiting factor.
I'm also not sure about disabling cores. In theory it should be straight forward. You should try doing it again at 4.5ghz just to see if it works.
Okay, but I have heard that BCLK tuning on SB systems can hurt them. Is this true?
I will try disabling cores at 4.5Ghz.
What exactly does PCI-E frequency do?
edit - to disable cores there is an option in the bios thats something like enable multi-cores. disabling it disables the extra cores in the cpu.
Windows also has a set number of cores feature that you can set in the win.ini file.
Well the one difference between SB and prior Intel chips is that the PCIe is tied directly to the base clock as opposed to being on it's own clock. That's why SB chips are so limited in OCing if they aren't unlocked. It's pretty sad, I mean my i5 750 is at 200 base clock, 110 PCIe, and only 20x multiplier on the CPU for 4ghz. My QPI is also super freaking fast at 7.4ghz lol.
Okay! Sweet! Thanks! I have heard some rumors about it causing damage to the CPU. I have been running 4.6Ghz for about 1 hour now. 98 x 47.
At a 98 BCLK and a 47 multiplier, one core ended at 4 hours into the run but all the others were stable all the way through. Kinda sucks. Really waned that 4.6Ghz. Oh well, 4.5Ghz is good enough for me and my single GTX 460. :lol:
Thanks for the help guys!
Yeah pretty much.
Not sure, honestly. As far as I know it's still a multiple of the base clock like my 1156 and the 1366 chipsets. Default for me I believe is 34x multiplier. But with SB they took out a lot of that fiddling room as you already found out with the base clock issue.
I kind of don't like the P67/Z68 chipsets because of this. The CPUs are fantastic but the motherboards are lacking features. My QPI is now 200x34 lol.
