Hello
Built a new computer about a week ago. i7-10700K, RTX 3060 Ventus 2x, Z490 Tomahawk. Worked fine for about 2-3 days and then i noticed it got slow. I look at all my monitor programs that my CPU runs at 800MHz (100x8). Long story short i found that the motherboard (that is what i assume sends the signal) says the CPU is too hot and throttles down to 800MHz. "BD PROCHOT" is the error signal that i get in ThrottleStop. All cores are stable at 30-40 C while idle and 50-60 C while playing Minecraft or CS at max settings 1080p 144Hz monitor.
So im wondering if this is anything u guys ever experienced. From my research it seems that this is a common problem for laptops, i only ever found a few instances on desktops from googling around.
Unchecking BD PROCHOT in ThrottleStop fixes the issue and everything is normal, but that is a safety feature, no? What i have done is: update BIOS, re-apply thermal paste, check for proper airflow and CPU cooler mounting, and checking that i got every driver downloaded from proper sources. From my understanding it should still throttle when it reaches damaging temps (activating PROCHOT, not BD PROCHOT) but i am still uncomfortable with leaving it off even tho every single temperature in my PC is normal.
I use a Corsair 4000D Airflow with 3 intake fans (1 stock, 2 Noctua) and one exhaust (stock). CPU cooler from Noctua (NH-U12S). PSU 850W from Corsair
Motherboard sensor faulty? Or CPU? All CPU temps are fine.
