Be quiet! Dark rock 3 inside Spec-01?
YadJomhur
16
I've been looking round the net, and the highest ''height'' cpu Cooler I can get is 165mm ( http://www.eteknix.com/corsair-carbide-series-spec-01-mid-tower-chassis-review/4/ ) inside the Corsair Carbide Spec-01. Although I'm not much to sure of the width possible. The Dark rock is 13,7mm wide, and I can't find any info on if it will fit in or not.
Any possible help?
