[SOLVED] Be quiet dark rock 4 in corsair spec-delta case
I wouldn't chance it. If it turns out that they rounded up to the nearest millimeter - some of them do - what will you do when you find you aren't able to close the side panel?
If the cooler were 158mm and the case clearance was 160mm, I wouldn't have a problem with it.
