Question Be Quiet! Dark rock 4, will i be fine for fitment?
lordtristan28
140
Hello,
I'm wondering if i pair a msi mpg x570s motherboard and Patriot Viper steel RGB ram with a be quiet dark rock 4 cpu cooler if i will be okay? I Honestly have no way of being sure.
Thanks!
Is this the motherboard you're looking at? You're going to be fine with that ram and CPU cooler combo. What you should be concerned about is the clearance inside your chassis. What chassis are you working with?
Yes that is the exact motherboard. Case is a fractal meshify c. I've seen online that it had clearance.
Do you think I could use all 4 dim slots with that cooler? Or do you think I'll have to only use 2 and 4.
