Question be Quiet PSU connections and cable length
finwizz
Great
Mar 3, 2019
128
4
85
Planning to use be Quiet Straight Power 11 750W PSU. The SATA cables seem to have special connector at the PSU end. I am also planning to use be Quiet 900 Pro Rev 2 full tower. I may need longer SATA cables and not sure if I can buy 3rd party ones as the PSU connector end can be a problem. Can anyone using this PSU / case advice please? Or is there an extension that I can use to extend the length of one SATA power cable to reach the external 5.25" bay if necessary?
PSU link:
https://www.scan.co.uk/products/750w-be-quiet!-straight-power-11-full-modular-80-plus-gold-sli-crossfire-quad-rail-625a-135mm-fan-at?gclid=Cj0KCQjwqs3rBRCdARIsADe1pfT9exB_cppNR-cyXH2qaWIpIOElyOtAhBeSHnMMQW61vrfwhvgFI0MaAquTEALw_wcB
jonnyguru
Where the cables plug into the PSU has never been "standardized". beQuiet has their own connections, Corsair has their own connections, Seasonic has their own connections. You can say they're all "special".
If you can't find beQuiet specific SATA cables that are longer, then you should just use extensions.
