I have a few installation questions regarding the be quiet! Pure Loop (360mm):
1. Does the radiator come pre-filled and topped up with coolant?
2. Where do I connect the 2-conductor cable that originates at the CPU block?
3. I installed the (3) fans to pull air from inside the case, push it across the radiator, and exhaust it out the top of the case. Is this correct?
Thanks for any replies, as always.
