Beats Wireless - Only one side works on Bluetooth, Both sides work on a wired connection
DearlyDeparted
21
Hi Forum,
I recently got a pair of Beats wireless (2013 model) handed to me to fix, but I can't figure out the problem.
On bluetooth only the right side (controller side) works the other is dead.., but when i plug them in using the 3mm jack both side work perfectly.
I'm guess is they are not under warranty and can't be returned. I also tried the reset method on the beats support site, but the headphones just don't want to do it.
Thanks for any and all help.
this I the solution. Works for me and my Cowin E7s. Just jiggle the aux chord in the socket and push at different angles and you'll get audio again.
Hey man! I was having the same problem with bluetooth with my computer. I looked in my bluetooth settings and found that somehow my audio settings got panned completely to one side. I put it back in the middle and it fixed it! Hope this hopefully helps you, or at least someone having this issue!
Jerron
This just worked for me!! After everything else didn’t, I just used the aux lead (not connected to anything) and tapped around the earphone insert hole whilst playing music. Sound back in both ears, how bizarre!!
Thank you !
I had the exact same problem. After trying resetting, aluminum foil, using the plugging technique, etc. without solving the issue and just getting sloppy results (just one side working, connecting via bluetooth but no sound ) I took apart the right side of the headphones, then pushed gently the little metal sheets of the plug. I believe the malfunction was due to wear and bad contact of the cable plug that made the headphones act all funny. Anyway, I did that and they are working just fine, both bluetooth and aux cord. Be careful because there are several tiny cables welded to the board and can be broken easily. Hope this helps.
GXZWR254mTSeoOPo.huge
