BEEP coming from PC while running
Fenderstrat91
7
Hi my pc has been making a beeping noise while its running windows. It is not the same noise beep that my pc makes when i turn it on its a lot lower and when it beeps my pc freezes for about 10 seconds then comes back to normal. I have also tried reseating the ram, ive checked to make sure my Hard drive was healthy. Any ideas on what this could be?
My specs
Amd Phenom 2 x4 925 oc to 3.5ghz - Water cooled temps under load are 40c
Nvidia GTX 660 SC - idle temp is 30c under load its 60c
8gb of ram
My CPU isn't that hot. I've noticed in many others posts, related to the same problem, that they say it's because of the mouse and replacing it with a new one resolved their problem. So i bought a new mouse but still i keep getting that noise. I also disconnected the keyboard and mouse, just to check, but still i keep getting that beep noise. So in my case i think the problem is not with the mouse or keyboard.
