While playing Skyrim (does not happen while rendering stuff or playing other games), my computer beeps 9 times, or more precisely, [beep-beep-beep-very shortpause]-x3. No CTD, sudden restart or shutdown. Just beeps and keeps going as if nothing happened. There is usually a 40 minute-1 hour spacing between beeping (tested this only once after the first time, those beeps are scary). My PC is pretty new and has been working flawlessly so far, even with Autocad, 3dMax and Photoshop running at the same time, and running even the latest games like Witcher 3 in ultra with no issues at all. Checked temperatures while playing and everything seemed fine (55C peak for CPU, 68C peak for GPU).
I am positive the beeps are coming from INSIDE the case. Searched the Internet and everyones seems to suggest that it is most likely a temperature problem. I cleaned the fans and case about a month ago. I will clean them again tomorrow to see if anything changes. Fans seemed to be working at full power while playing (mainly because the game is heavily modded), but nothing out of the ordinary.
Other than that, it is pretty hot where I live lately, around 30C AND there are power issues from time to time (lower tension than usual, and sudden energy outages). PC seems to be doing just fine though, so my first guess is that the PSU is okay.
Some forums also suggested that it might be a bad memory issue due to the beeps, but I guess it is not. PC should beep during startup if this was the case.
Specs are FX6300, GIGABYTE r9 270x, 8gb RAM, Windows 7. GIGABYTE motherboard.
