[SOLVED] Beginners guide to liquid cooling my CPU
zrkraus
68
So since I built my pc back in 2016, I've used air cooling to take care of my cpu. Recently however, I've put some thought into switching over to liquid cooling, mostly due to the low profile and softer noise. I always thought they were a hassle in the past, but honestly I know almost nothing about them. So all im asking for is the need-to-knows of liquid cooling. Specifically: what is a good model to sit on an i7 8700k w/slight OC, what sorts of fluids are used in water cooling, maintenance, and all the basic components that go into it.
Stick with air cooling.
Only if you are seeking maximum overclocks might a 360 aio be appropriate and more effective than a good dual tower air cooler.
One problem with max overclocks is necessary higher voltage which will reduce the life of your processor.
With a mechanical pump, reliability of a liquid cooler will be less than a air cooler.
While uncommon, liquid coolers do, on occasion leak.
Here is a link to some images when I googled "h100 leak"
https://www.google.com/search?q=h10...CQKwKHYCBDB0Q_AUoAXoECAwQAw&biw=1653&bih=1305
