Belkin 75D7000 PCI Card Driver Problem
smigza
Hi,
I just finished building a PC, which uses this card.
I know that the card uses the RALINK RT2500 chipset. I downloaded and installed the Ralink RT2500 drivers, and manually setup the card using the Windows 7 Device Manager.
The card was working perfectly until I decided to remove it from its PCI slot, and the booted up the PC.
Windows 7 still detects the card, but tells me that there was an error in installing the drivers.
I uninstalled and re-installed the RALINK drivers. This has not solved the problem.
Can someone please give me some advice here.
Thanks.
May be a resource issue. Try a different PCI slot.
If no joy, go into BIOS and disable ports you won't be using -- COM, Game/Midi, Parallel Printer (if using USB printer). Restart Windows to reassign resources.
Hi Fihart
Thanks for your help.
I removed the drivers, shutdown the computer, took the wifi card out of the pci slot and rebooted the computer.
I then removed all registry entries associated with the pci card.
I shutdown the computer again, re-installed the card, rebooted and re-installed the driver.
Everything works as before!!!
Cheers
