Ok so ive done a lot of reading around online about this and cant find info that helps me, hoping someone here can shed some light on this...
I added a 500 GB samsung evo SSD a few months ago and i just got around to benchmarking everything because i was curious. The SSD is less than 25% full, and is all 1 partition.
Im using "NovaBench" to test, and when its done it says my write speed is 108mb/s
I closed all other programs, tried a few times, its the same each time.
I also use "samsung magician" and set it to high performance, and yes AHCI is enabled. I also enabled the RAPID mode but that didnt change anything.
I built the pc myself, and yes i am using a SATA3 cable and its plugged into a SATA3 in my mobo
here are the rest of the specs:
AMD FX 6300 CPU
Asus M5A96 LE mobo
GeForce GTX 660
16 GB DDR3
windows 10
thank you very much for the help!
AMD FX 6300 CPU
Asus M5A96 LE mobo
GeForce GTX 660
16 GB DDR3
windows 10
