Hello,
I have a BenQ G2420HDB that very often starts flickering and goes completely black.
If I adjust the DVI connector on the monitor I can get it to work again, but it is a pain since it happens very often (several times per 10 minutes). I have already ruled out my GFX card and cables to be the problem since they have been switched out to new ones. I believe that the DVI connector on the monitor is somehow loose. I can't test the VGA slot since my GFX card isn't compatible.
If anyone have any tips on how to fix this issue then please tell me.
Thanks in advance.
Thanks in advance.
