Bent Pins and Solders in First Build.
josefk
22
Hello! It's my first time building and it seems I've bent 3 CPU pins on my Ryzen 1600. I then panicked and I'm pretty sure I bent some of the soldered things on the back of my Asus Strix B350-F motherboard as well (not the socket). I don't actually know for sure if I bent the pins, but I can't imagine it being anything else so I assume RMA'ing to Amazon UK is out of the question.
1. For the 3 adjacent bent CPU Pins, googling seems to suggest methods involving credit cards, toothpicks, mechanical pencils, tweezers, etc. What method is easiest and most effective? I'm honestly worried that I'm just going to make things worse.
2. None of the bent motherboard solders seem to be touching anything else. Is this actually not a problem?
3. I was using the motherboard box as the assembling area. Is it actually safer to build in the case on top of the standoffs to avoid messing with the back of the motherboard?
I included some pictures below. Sorry that I don't have anything that can take better pictures.
Thanks in advance.
1. The 'best' method is what works for you.
I have used all three....mech pencil, large needle, credit card.
Bent pins may/probably will prevent actually putting it in all the way.
Or, those slightly bent pins get bent way worse than they are now when you force it in. They need to be straight.
2. The bent pins on the back are fine, if they are not touching anything else.
3. Assembling and testing outside the case is often good, because if anything is 'wrong/DOA', you don't have to take everything out and then rebuild.
Thanks! I think I'm going to try a mechanical pencil first. Looked through a few sites and videos and it doesn't seem too worrying. Worst comes to worst I'll try the local PC repair shop. Hope this doesn't affect overclocking.
