Best 1150 CPU Cooler for $50 or less?
It doesn't support socket 1150.
I won't be SLI-ing. I will only have one GTX 780.
I'll be playing on 1920x1080--normally I play in a 1600x900 window (less constraint on eyes). I am already above my $1300 budget, but I felt like the next-gen stuff was a must.
The best aftermarket cpu cooler in that price range is the cooler master hyper 212 evo and the cooler master v6.I have used many different aftermarket cpu coolers at one time or another. When i use to work at a computer store. I test alot of aftermarket cpu coolers and those were the best in the fifty dollars or less price range. Now if you want to up you're budget a little bit.I would recommend the NH-D14 or Phanteks PH-TC14PE.
If nothing else, pickup this 4670K + MSI Z87-G45 combo for $320
CPU: Intel Core i5-4670K 3.4GHz Quad-Core Processor ($239.99 @ Newegg)
CPU Cooler: Cooler Master Seidon 120M 86.2 CFM Liquid CPU Cooler ($34.99 @ Newegg)
Motherboard: MSI Z87-G45 Gaming ATX LGA1150 Motherboard ($149.99 @ Newegg)
Memory: G.Skill Ripjaws X Series 8GB (2 x 4GB) DDR3-1866 Memory ($64.80 @ Newegg)
Storage: Western Digital Caviar Black 1TB 3.5" 7200RPM Internal Hard Drive ($76.99 @ Best Buy)
Video Card: EVGA GeForce GTX 780 3GB Video Card ($659.99 @ Amazon)
Case: Corsair 300R ATX Mid Tower Case ($49.99 @ Newegg)
Power Supply: XFX 750W 80 PLUS Bronze Certified ATX12V / EPS12V Power Supply ($74.99 @ NCIX US)
Optical Drive: LG GH24NS95 DVD/CD Writer ($14.99 @ Newegg)
Total: $1296.72
All socket 1155 coolers are compatible with socket 1150
IMO this sub 1200$ setup is good for all your needs. Well-themed and well-ventilated. No need for a 780 since it's only 10% more powerful than a 770 and you only play at 1080p :
CPU Cooler: Cooler Master Hyper 212 EVO 82.9 CFM Sleeve Bearing CPU Cooler ($29.98 @ Outlet PC)
Memory: Corsair Vengeance 8GB (2 x 4GB) DDR3-1600 Memory ($59.99 @ Newegg)
Storage: Samsung 840 Pro Series 128GB 2.5" Solid State Disk ($129.98 @ Outlet PC)
Storage: Western Digital Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive ($65.98 @ Outlet PC)
Video Card: MSI GeForce GTX 770 2GB Video Card ($399.99 @ Amazon)
Case: NZXT Phantom 410 (Black) ATX Mid Tower Case ($79.99 @ Newegg)
Power Supply: Antec High Current Gamer 620W 80 PLUS Bronze Certified ATX12V / EPS12V Power Supply ($79.99 @ Amazon)
Total: $1180.87
(Generated by PCPartPicker 2013-06-21 01:28 EDT-0400)
All LGA1155 coolers are compatible with LGA1150 motherboards, additionally. Since the 2 sockets have same CPU cooler mounting holes.
Thanks, but can you tell me why the motherboard weak? I won't have SLI'd cards as many games don't support it, and it is more expensive.
The board you picked is weak because it can't handle overclocking well, and that's it.
