guitarmatt99 Honorable Oct 14, 2013 143 0 10,710 Apr 18, 2014 #1 Hello, I wan't to know what is the best 1TB HDD for under £50 is? (for performance)
Rationale Admirable Mar 21, 2014 3,025 1 7,960 Apr 18, 2014 Solution #2 http://www.amazon.co.uk/dp/B0088PUEPK/?tag=pcp0f-21 That. Upvote 1 Downvote Solution
STACKS ON DECK Distinguished Dec 28, 2013 1,748 0 20,460 Apr 18, 2014 #3 http://uk.pcpartpicker.com/part/western-digital-internal-hard-drive-wd1003fzex Upvote 0 Downvote
Rationale Admirable Mar 21, 2014 3,025 1 7,960 Apr 18, 2014 #4 STACKS ON DECK : http://uk.pcpartpicker.com/part/western-digital-internal-hard-drive-wd1003fzex The HDD you selected is actually a bit slower. It ranks 40th in speed instead of 29th. http://hdd.userbenchmark.com/Compare/WD-Blue-1TB-2012-vs-WD-Black-1TB-2013/1779vs1822 Upvote 0 Downvote
STACKS ON DECK Distinguished Dec 28, 2013 1,748 0 20,460 Apr 18, 2014 #5 i used both blue and black myself . . black is more good as i saw Upvote 0 Downvote
das_stig Glorious Jul 24, 2009 8,627 220 46,390 Apr 18, 2014 #6 If speed important or not bothered by the extra few ££ in costs, get the WD Black, else get the WD Blue. Upvote 1 Downvote
Y Y0GI Splendid Jul 22, 2013 4,745 0 24,960 Apr 18, 2014 #7 If you want the fastest 1 TB drive, get the Seagate ST1000DM003: http://www.amazon.co.uk/Seagate-ST1000DM003-Barracuda-inch-Drive/dp/B006BRBSE8/ref=sr_1_1?s=computers&ie=UTF8&qid=1397835584&sr=1-1&keywords=seagate+st1000dm003 Data Sheet: http://www.seagate.com/staticfiles/docs/pdf/datasheet/disc/desktop-hdd-data-sheet-ds1770-1-1212us.pdf Note the "Max Sustained Data Rate: 210 MB/S! I have this drive and it is quiet, reliable and VERY fast! Highly recommended! Yogi Upvote 1 Downvote
guitarmatt99 Honorable Oct 14, 2013 143 0 10,710 Apr 18, 2014 #8 Y0GI : If you want the fastest 1 TB drive, get the Seagate ST1000DM003: http://www.amazon.co.uk/Seagate-ST1000DM003-Barracuda-inch-Drive/dp/B006BRBSE8/ref=sr_1_1?s=computers&ie=UTF8&qid=1397835584&sr=1-1&keywords=seagate+st1000dm003 Data Sheet: http://www.seagate.com/staticfiles/docs/pdf/datasheet/disc/desktop-hdd-data-sheet-ds1770-1-1212us.pdf Note the "Max Sustained Data Rate: 210 MB/S! I have this drive and it is quiet, reliable and VERY fast! Highly recommended! Yogi I've heard that the WD blue is more reliable, so I think I may go with that, thanks for the input anyway. Upvote 0 Downvote
S sora Splendid Oct 30, 2013 7,812 0 31,460 Apr 19, 2014 #9 guitarmatt99 : Y0GI : If you want the fastest 1 TB drive, get the Seagate ST1000DM003: http://www.amazon.co.uk/Seagate-ST1000DM003-Barracuda-inch-Drive/dp/B006BRBSE8/ref=sr_1_1?s=computers&ie=UTF8&qid=1397835584&sr=1-1&keywords=seagate+st1000dm003 Data Sheet: http://www.seagate.com/staticfiles/docs/pdf/datasheet/disc/desktop-hdd-data-sheet-ds1770-1-1212us.pdf Note the "Max Sustained Data Rate: 210 MB/S! I have this drive and it is quiet, reliable and VERY fast! Highly recommended! Yogi I've heard that the WD blue is more reliable, so I think I may go with that, thanks for the input anyway. It is a lot more reliable. WD is known for making higher quality SSDs. Upvote 0 Downvote
