Best 600w+ power supply under $65
djett427
429
Hey guys! I'm extremely worried about my new build with a viotek 850w psu. I want to get a new, reputable power supply for my build. It doesn't matter if it is modular, semi-mod, or non-mod. I'm just looking for the cheapest 600w power supply I can get from a good brand. So what are your all's suggestions? Thanks!
Yes, I really need a 600w PSU. I plan on a crossfire with 2 Sapphire R9 270x's.
The 270X's are what, 175W cards? Two would be 350? Add in a 125W AMD CPU (guessing worst case as you didn't give system specs and you are up to 475. I use 50W for the rest of the system and some cushion, so that brings you to 525. According to Amazon's link it has 46A on the 12V rail, or 552W. That's REALLY closet to the max. You might want to get a 750W.
What would you recommend?
Well, looks like I will be spend more $$$. What do you recommend?
The thing that really gets me though, is that it isn't modular at all.
Good idea
I'm sorry, I thought you said you didn't care. All the good modular ones are over $100, which is a much larger price increase. Seeing as you'd be using so many cables anyways, I don't feel it's worth the increase in price.
Very true.
