Hi everyone, I'm looking to build my first computer and I was hoping I could get some advice on what components would best suit my needs. My current rig is a HP Pavilion p7-1027c that I've been using for the past few years with the following specs:
Current Build:
CPU: Intel Core i3-2100 @ 3.10 GHz
Motherboard: Pegatron Carmel Motherboard
RAM: 6GB DDR3 -1333
GPU: MSI GTX 660 2GB GDDR5 OC Edition
PSU: EVGA 500B
I'm now looking to build my own PC as I feel my processor needs an upgrade. I use my computer for a lot of 3d rendering, video and image editing, and audio recording with programs like Blender, Unity, Photoshop and Reaper. I'm also a casual gamer, but I'm not concerned with getting ultra graphics out of my rig so I'm hoping to continue using my GTX 660 to save on costs. Primarily I would like to upgrade to a processor that will be more future-proof and I would like to have at least 16GB of RAM with the option to install more. I'm looking at spending around $800 (Canadian) on the components, but I'm flexible with this price. After doing some research this weekend I've come up with the following build:
New Build:
CPU: Intel Core i7-4790k @ 4.0 GHz - $410
MOBO: MSI Z97 PC MATE ATX LGA1150 Motherboard - $100
RAM: Crucial Ballistix Sport 16GB (2 x 8GB) DDR3-1600 Memory - $110
Storage: Seagate Barracuda 1TB 3.5" 7200RPM Internal Hard Drive - $55
PSU: EVGA 500B
Case: ?
Cooling: ?
Total: $675
I'm not as familiar with hardware as I am with software so please correct me if there are any flaws to be found in this build. I also have a few question about the hardware:
1. Will my EVGA 500B have enough power to safely run this build? I know it has worked fine running my GTX 660 since I installed it, but I'm not sure if the other components will be more demanding.
2. I doubt that this is possible, but would I be able to re-use my old HP case for my new build? If not, can I get away with purchasing a cheap case in order to cut costs a bit?
3. Should I be purchasing a cooler to add to this build? If so, how much should I invest in a cooling system?
I apologize for this lengthy description, but I would greatly appreciate any advice you have to offer. Thank you in advance for the help!
Current Build:
RAM: 6GB DDR3 -1333
PSU: EVGA 500B
New Build:
PSU: EVGA 500B
Case: ?
Cooling: ?
Total: $675
