I am looking to get a 5960x and I will most likely OC it to 4.0-4.4 Ghz. I am looking for the best AIO Cooler to keep the idle and load temps as low as possible. I plan on using the Asus Rampage V Extreme Mobo if that helps My case roof supports 2x230mm fans, 3x120 mm fans and 3x140mm fans. I may consider doing a custom loop but I am really scared to do that myself and have heard that maintenance is a pain as well. Thanks everyone!
