Best AIO Water Cooling
Im_Infinity
593
basically the title shows my question what is the best all in one water cooler you can buy which is a dual 120mm fan i have the corsair h100i and wanna get a better one thanks for suggestions
mostly just gaming but games that are cpu intense like arma 3 and the division
And that's perfectly normal. Low even. So what's the problem?
And honestly a 4770K to 4970K will not be a noticeable upgrade. Just a waste of money.
well i started looking at different coolers and noticed there was a h100i v2 so i started to wonder if there was any aio coolers better than my current one
is skylake any good only bad thing i heard about them is there trying to stop you from oc them
My 6700K is perfectly stable at 4.6Ghz. It overclocks fine. But there is no reason to upgrade Haswell to Skylake. You will see a big 5-7% performance increase clock for clock and that's only in certain situations.. Certainly not worth spending money on a CPU, motherboard and new RAM for the 1 or 2 FPS you would get. If you want better gaming performance you need a better graphics card.
Your 4770K should do 4.1Ghz -4.2Ghz on stock voltage with no problems.
hehe i have a 980ti and when i tried 4.2 on stock i got bluescreen after a couple of hours
