M Moiz51 Honorable Sep 25, 2016 57 0 10,630 Oct 15, 2016 #1 Please can anyone tell me the best air cooled case under $100 which must have room for 1 DVD rom and also with a side window. Thank you in advance.
Solution Isokolon Oct 15, 2016 Check Out the Thermaltake F31 It's basically an improved Fractal Design R5 usually for under 100$ With quality sound dampening and good expandability
Justiceinacan Admirable Jul 19, 2016 2,042 0 6,960 Oct 15, 2016 #2 What form factor? If it's M-ATX the Corsair Air 240 is fantastic. I love mine. The Air 540, it's bigger cousin, goes over 100 sadly... Upvote 0 Downvote
badboyrog2 Distinguished Mar 5, 2014 6,953 0 18,960 Oct 15, 2016 #3 which pc case you have? Upvote 0 Downvote
M Moiz51 Honorable Sep 25, 2016 57 0 10,630 Oct 15, 2016 #4 http://pcpartpicker.com/list/qH4vRG This is my build.. Can't decide a case.. Upvote 0 Downvote
badboyrog2 Distinguished Mar 5, 2014 6,953 0 18,960 Oct 15, 2016 #5 the cpu cooler you bought is perfect ..good choice http://www.newegg.com/Product/Product.aspx?item=N82E16811854037 Upvote 1 Downvote
badboyrog2 Distinguished Mar 5, 2014 6,953 0 18,960 Oct 15, 2016 #7 did you checked my link above? Upvote 0 Downvote
M Moiz51 Honorable Sep 25, 2016 57 0 10,630 Oct 15, 2016 #8 Thanks badboyrog2 I will take your case into consideration. Any more suggestions guys please I need more options. Upvote 0 Downvote
M Moiz51 Honorable Sep 25, 2016 57 0 10,630 Oct 15, 2016 #9 Yes i did checked your link badboyrog2.. I am looking options specially in coolermaster or corsair or may be thermaltake.. Upvote 0 Downvote
badboyrog2 Distinguished Mar 5, 2014 6,953 0 18,960 Oct 15, 2016 #10 Carbide Series® 300R Thermaltake Core X31 Upvote 1 Downvote
Dark Lord of Tech Retired Moderator Aug 18, 2009 128,731 1,824 159,590 Oct 15, 2016 #11 http://www.czone.com.pk/casing-corsair-casings-corsair-carbide-series-200r-black-steel-plastic-compact-atx-mid-tower-case-window-panel-cc-9011041-ww-pakistan-p.4193.aspx 200R or http://www.czone.com.pk/casing-corsair-casings-corsair-carbide-series-100r-silent-edition-mid-tower-case-cc-9011077-ww-pakistan-p.4199.aspx 100R SE Upvote 0 Downvote
Isokolon Judicious Jul 24, 2016 6,369 108 34,390 Oct 15, 2016 Solution #12 Check Out the Thermaltake F31 It's basically an improved Fractal Design R5 usually for under 100$ With quality sound dampening and good expandability Upvote 1 Downvote Solution
M Moiz51 Honorable Sep 25, 2016 57 0 10,630 Oct 16, 2016 #13 I have checked the casings you guys have suggested i think i may go with thermaltake f31.. But still i have not decided yet so i am still open for suggestions and willing to increase the budget to $120. Upvote 0 Downvote
