best air cpu cooler with height under 150mm
Noctua D14 is 160mm. That wont fit. Infact all the good tower coolers are above 150mm.
Cryorig H7 is your best bet. You can also check out the "be quiet! - DARK ROCK TF".
But your options are mostly AIOs.
Cooler Master H100i V2 should be good.
Yes, you are correct. I misread the dimensions of the D14.
