Hello I'm looking for a case that is roomy, with plenty of fan mounts(6-7), filter for bottom mounted PSU, and room for a long GPU and SSD and a Hyoer 212 EVO, and good cable management. A side window with side fans and radiator support is preferred.
Specs:
FX8350 with Hyper 212 EVO
EVGA 600B 80+ bronze PSU
1TB Bhard drive 3.5 inch
64GB SSD 2.5 inch
GTX 770
Gigabyte GA970-D3P ATX
5.25 inch DVD burner
My current case has very bad airflow and bad cable management. It supports 2 80mm fans and has 12 mm space behind mobo. I'm looking for a case maximum of $55 including shipping.
I was looking at:
DEEPCOOL Tesseract
NZXT source 210 elite or source 220
Corsair carbide SPEC01
Fractal design core 2300
or any other case that you can suggest I go for? Which has best performance for overclocking and good airflow?
Btw there is a local Best Buy and Microcenter
Specs:
64GB SSD 2.5 inch
GTX 770
I was looking at:
DEEPCOOL Tesseract
