[SOLVED] Best ATX PC Case for under £150
Their not really a best case, their a bunch of good cases with different looks. It really depends on what you like your the one going to be seeing it every day.
Then you take into consideration of if your water cooling, like RGB amount of drives being used along with other parts.
EDIT for example if I was buying a new case today I would buy this one and add blue LED fans. Good case (just as good as any) has the looks I like, I rather have just blue led fans not RGB but that is just my likes you can ask 100 different people and get 50 different answers.
https://uk.pcpartpicker.com/product...te-tg-atx-mid-tower-case-fd-ca-mesh-s2-wt-tgc
Then you have people that will just buy a budget case...
Then you have people that will just buy a budget case for around 50 bucks their not wrong either that leaves them a extra 100 bucks to buy a better video card, processor, or larger SSD if they had 150 to spend on a case.
As long as the case holds all the parts, and has adequate cooling for the parts is all that matters the rest just comes down to what you like.
