Looking for a replacement for my god awful EVGA DG-76. However it's proving difficult to find any that fit my needs as almost all cases I can find being recommended have tons of issues with few matching most of my minimum requirements.
Budget: Less than $100
Minimum Requirements:
Size: ATX, Physical size doesn't matter, must fit very large graphics cards and large CPU coolers,
Looks: Clean, Square flat (normal PC no bulges), and black
Front I/O: Power, Power LED, Reset, Headphone jack, microphone jack, and 2 USB 3.0
Exterior: Mesh front, lots of dust filters, easy to remove and clean dust filters,
Features: 2x 240mm RAD support, 4x Harddrive bays or 6x if no 2.5 spots, really good and easy cable management, really good airflow, easy to build in,
Note: These are bare minimum requirements for me so anything extra is a plus but anything missing means no.
Things I dislike about my current case: God awful airflow, horrific cable management, cheap and difficult to remove dust filters on all but front, no harddrive bays, have to mount 240mm AIO in front, complicated and time consuming to add and remove PCIe cards (Have to unscrew and take off back, unscrew and take off side, unscrew and take off back plate, and then can finally unscrew and take out/put in PCIe card), sticker on glass side, tinted side,
Thanks 😀
Thanks 😀
