Hi All,
I'm looking for a power supply that will satisfy all my needs.
Here is my current rig and will be upgrading to Ryzen soon:
Motherboard: GIGABYTE GA970A-DS3 rev 3.0
Processor: AMD Athlon II X4 640
RAM: Avexir Red LED DDR3 1600 2X4GB RAM
GPU: Zotac GTX 780 Reference Cooler
PSU: Aerocool VP Pro 500w 80 plus Power Supply
Case: Aerocool Strike X One (Will be upgrading to NZXT H440 v2)
Cooler: Deepcool Maelstrom 240L
And here is changes in my rig in the Future
Motherboard: Asrock X370 FATAL1TY Gaming K4
Processor: AMD Ryzen 5 1600
RAM: TBD (Still deciding what RAM frequency and size would be the best option)
PSU: TBD
Case: NZXT H440 v2
# of Case Fans Running: 8
- 1 Top (Exhaust)
- 1 Rear (Exhaust)
- 2 Side (Intake)
- 4 Fans in the Radiator (Push-Pull Config)
When I try to set this rig up, I never expect that my PSU would handle these configurations, but it did.
Well currently I'm not doing some heavy stuff knowing that any time it might shut down.
The things that I'm currently doing in my PC is just playing one game (AC:Rogue), and some for Home use only.
I want to upgrade my PSU because for future use since I'am going for the Ryzen Build and I don't want my PSU fry those brand new components.
So here are the PSUs I'm gaining my Interest to. My current budget is that I must not go higher than 4000 pesos ($80)
- Seasonic M2II 620w EVO 80+ Bronze: Php 3790
- Corsair CX650M 650w 80+ Bronze: Php 3600
- FSP Raider 750w 80+ silver: Php 3450
- Thermaltake Smart SE 630w 90% GOLD Modular Power Supply: Php 4000
- Cougar VTX700 80+ Bronze 700watts: Php 3300
- Cougar VTX700 80+ Bronze 600watts: Php 2800
- Corsair VS650 Power Supply: Php 2750
The main thing that I'm going to do in my PC is Gaming + some programming also.
Which of these power supply would suffice my needs? Budget wise?
Also if you want to recommend a power supply that is not on the list, feel free to tell me, I might find a way to buy that power supply.
That's All, Cheers and Thank you in Advance. 😀
PSU: TBD
Case: NZXT H440 v2
- 1 Top (Exhaust)
- 1 Rear (Exhaust)
- 2 Side (Intake)
