Question BEST build for gaming/live streaming at max settings in the Philippines?
Brandon Umali
42
Hi Everyone,
Good Day! Hope you're all safe and well.
I am planning to build a new and better gaming/live streaming build with 100K to 150K Php budget at max settings here in the Philippines.
What do you guys recommend?
The games I'm playing and doing live streaming so far are the following:
WAR TALES
COD
THE WITCHER
NBA 2K
GTA V
DOTA 2
CS GO
VALORANT
the selection in your country is really limited and prices are a bit high
looking at some of your local vendors the best i could come up with
approaching your budget was this :
storage needs improvement - it would be ideal to get 2tb (and faster) m.2 drive
at least kingston P3 plus /P5 plus or even better KC3000/fury renegade or WD black SN770/SN850X
if you could find one of those in 2tb version for a decent price it would be great .
also try to look for coolers like deepcool AK400/or arctic duo esports if you can find one .
and ASUS B550 TUF GAMING PLUS II motherboard would also be nice if you can find it .
Hi Everyone,
WAR TALES
COD
THE WITCHER
NBA 2K
GTA V
DOTA 2
CS GO
VALORANT
What is your monitor resolution or do you need a monitor?
https://dynaquestpc.com/collections...pse-p360a-air-tg-drgb-black-ph-ec360atg_dbk01
PHANTEKS ECLIPSE P360A AIR ₱4,200.00
https://dynaquestpc.com/products/omega-halo-120mm-white-blade-case-fan
OMEGA HALO 120mm 4-Pin CASE FAN ₱180.00
https://dynaquestpc.com/collections...-gold-750watts-80-full-modular-psu-mpg-a750gf
MSI MPG A750GF 750W 80+GOLD MODULAR PSU ₱5,995.00
MSI MAG B550 TOMAHAWK MAX WIFI ₱10,780.00
https://dynaquestpc.com/collections...m4-must-be-bought-with-compatible-motherboard
AMD RYZEN 7 5700X ₱11,650.00
https://dynaquestpc.com/products/cooler-master-hyper-212-spectrum-rgb-cpu-cooler-rr-212a-20pd-r1
COOLER MASTER HYPER 212 SPECTRUM RGB CPU COOLER ₱1,999.00
KINGSTON FURY BEAST DDR4 3600MHZ 32GB (2x16GB) CL18 ₱5,750.00
https://dynaquestpc.com/collections...-laptop-pcs-ssd-solid-state-drive-snv2s-2000g
KINGSTON NV2 2TB PCIE 4.0 NVME M.2 SSD ₱5,320.00
https://dynaquestpc.com/collections...060-ti-eagle-oc-d6x-8gb-gv-n306txeagle-oc-8gd
GIGABYTE RTX 3060 TI EAGLE OC 8GB ₱25,670.00
https://dynaquestpc.com/collections...z-1920-x-1080-fhd-1ms-freesync-gaming-monitor
LG 24GN60R-B 24" ULTRAGEAR IPS 144HZ (1920 X 1080) FHD IPS 1MS FREESYNC / G-Sync Compatible GAMING MONITOR ₱9,950.00
Total: ₱81494 / $1464
A better look at those components.
https://www.lg.com/us/monitors/lg-24gn60r-b
https://www.phanteks.com/Eclipse-P360A.html
https://www.msi.com/Motherboard/MAG-B550-TOMAHAWK-MAX-WIFI
Reactions: Brandon Umali
Wow! This is a lot cheaper than what I've got my budget on. If you could maximize my budget what would you recommend? I would love to do a dual monitor setup as well.
Reactions: Why_Me
